What shifter w/Stageright & 2 Step on micro switch
kidrick
I'm thinking of the B&M Pro Stick. My plan is when I engage the brake in 1st, I will have a micro switch that sets the two step at the lower rpm. Then when I launch the car by shifting into 2nd the micro switch will automatically change the two step to the high rpm setting. Then I will just manually shift to 3rd. My issue is that i can not use a ratchet shifter with the micro switch because when I rachet it from 2nd to 3rd I may reactivate the low rpm on the two step. Also will the Pro Stick gate stop me from oveshifting(1st to 3rd) like a rachet would?
i use the stocker for the stageright with some mods to the gate to ensure you wont go past fourth into neutral
i adjusted the button so you have to reach in with your thumb to get into 1st and then all i do is push it forward into 2nd which releases the stage brake then to third , and sometimes to 4th
for two step the micro switch is set on the passenger side of the shifter and is depressed upon shifting to low (1st) and to disengage the moment you click out of first , ont he older msd dis 4 the switch must be grounded to activate the stage limiter , once you come off the stage it switches over to max rpm limiter ,
