jasons kwik 6
- Oct 28, 2001
I cant find D5 stamped on it anywhere. Anybody have one laying around? Thanks
SignUp Now!Originally posted by trading t/a
From the factory the TTA is supposed to have a D5 converter. Your car is the second one I've seen with a D6. The stall of a D6 is lower thatn that of a D5(not really a performance converter). I believe the cutlass,monte and 307 regals came with the D6 converters. I took mine out less than 2 weeks ago and it was a D5.
Originally posted by Grumpy
hmmmm should have a "CBCF" if my mind is workin right...its a tag on the stock original converters from GM
Originally posted by skturbo
The TTA and the GN had the same converter. D5 CBCF. If you have a D6 you have the wrong converter.(common problem) Also to check your stall hook up a vaccum-boost gauge. Torque your car up ,when you reach 0 boost check your rpm thats your stall.
Steve K.
Dan, Hows the TTA coming?
I thought they were D5's. Does that mean some of the tranny shops replace them with 6's or did they goof up in the factory(like with the spare tire).
I have 7 complete TTA transmissions w/converters never been touched. I have been building TTAs since the begining.
Sometimes regular trans shops would put the wrong converter in. They will look up 200r4 in there book and see it calls for a d6. put it in and screw the car up.
Steve Kaminski
