what should i run?
no-nos
Junior Member
hay guys, i've never taken my car to the track, but what do you think i'm running :confused: , i have what's on my signature, i've done the spring cleaning thing, the timming belt was changed to a steel one, I just changed my spark plug wire's the ones i had on were :eek: , i put moroso's 8mm blue wire ( i don't know if they'll help with performance? but they sure do look good :D )and i have no cat, it's a stright pipe to the mufflers. I think maybe mid to low 13's? I HAVE NO IDEA :confused: , and one last thing i'm not sure what type of chip i had installed, I've learned that the place where i took to get these goodies installed, has in the past substituded( is that right?) parts. I had the car checked and do know i do have 009's and everything else but the chip? I read that turbotweak is the place to call for a chip? or is there better? I appreciate the feed-back ;)
thanks,
C.E.
high 12's with a good chip from Eric marshall, sticky tires. Removed front sway bar. Do you have a Adj Fuel pressure regulator? What about Adjustable wastegate? Will you run race gas or pump gas? Talk to me goose lol :tongue:
thanks for the reply bescurred, yes i do have an adj-fuel-pressure regulator, i will run race gas and no-no adj-wastegate, Eric Marshall ( I take it thats the eric from turbotweak ? :redface: ) I can get my hands on some slicks, high 12's would be nice :D , I see your about to break into the 11's :D must be nice. Thanks again
goose out :D
Glad you ditched the timing belt, that would have caused problems right there.
Mid 14's, I'd bet on it.
goose out :D
IF your running ras gas you need to be able to turn up the boost and you need a ScanMaster to watch your 02's...mid 14s? what the heck is that dude smoking? My car is pretty much the same plus a 3" THDP,scan tool and a powerplate. Mid 12's with a good launch, boost turned up, and you can monitor your 02's if its not to hot of a day.
agghh
mid 14"s, i hope not, i would become the invisible driver :D , it would be horrible a gn running 14"s, why i'd get kicked out of every buick club there is, id be known as the guy who ran 14"s aaaagggghhhh :eek: :eek: :eek: j/k
i hope not :redface:
good advice :) i'll keep that in mind (scanmaster) how high should i take the boost up to? 20lbs or 22lbs ?
thanks good info :cool:
Are you running a stock turbo? Stock IC? Stock chip? If you don't have a Scanmaster don't do anything until you do. You have to be able to monitor O2 numbers and timing retard ( knock ). If you have a non adjustable wastegate actuator you won't be able to increase boost. If you can adjust boost, on a stock turbo 20-21psi is about as productive as it will get.
If you get a SM which you HAVE to have...ask your buddy to borrow it, When I last ran with the stock turbo and intercooler I ran 22PSI...however you MUST have a scanmaster. Also yes that chip is from Turbotweaked.
shall do , scanmaster is no problem ( my bud's got one) and i guess i will be ordering a chip tonight :biggrin: ,
thanks fellas :)
Hey Carlos, maybe Freddy can hook you up with the in car boost controller, he put one in my car & he has one in his car. It's nice to be able to adjust the boost on the fly. And so much easier than burning your fingers on that hot @#%$ rod. What I don't know is if you have to have an adjustable wastegate rod for it to work.
cool
not a bad idea eddy , i'll ask freddy, i'm taking him the car this week, i hope he enjoyed his little get-away :D i'll see what he says , good to hear from ya :)
you have never raced the car and ya think ya just jump in an go 12s :rolleyes: .. Ill say high 13s to low 14s.. :eek:
i've raced before, i just have'nt race'd this gn, but i see your point you gatta test and tune ;)
Grumpy says it, you understand. I say it, you don't. :confused:
Anyway, these cars don't have timing belts. I was being sarcastic.
