SignUp Now!You got the scanmaster. Good job. Do you have an adjustable regulator? Set the static FP (line off) at about 42psi. And get a TT chip. Its the best $80 you could ever spend on your TR.
No I do not have an adjustable fuel reg. :frown: Just this little jobby....
I'm guessing that's the stocker....right?
And this is the chip I have:
Not sure what it is but I'm told it's not stock. My engine has the #36 lb blue top injectors. Current boost level is 14 lbs.
I plan on getting the hot wire kit.
I also plan on doing the spring cleaning.
As far as the fuel pump....do I need to drop the gas tank to do this?
Can I take the pump that is in there now and verify what it is somehow?
I have an Autometer 3780 tach, hope that's a good tach. :smile:
What is the pulsator you speak of?
What is wrong with this chip?
Its a brass one way check valve, i would check it to see if it works..
The parts store pcv valves leak under boost, and the GM ac delco ones work a little better.
Ive always used the ATR check valves in my cars, keeps me from changine out gaskets and seals:biggrin:
BW
I would have kept the ATR piece in the car, under boost, the GM pcv valves will leak under high boost. But they are better than the napa ones
If it leaks pressure while under boost, you will putting pressure on the bottom half of the motor, probably pushing out the dipstick and oil past the rear main seal.
So yes, IT IS solely designed to be a better part than a stock PCV?
Dont worry, its not supposed to rattle like a standard pcv valve
BW
