F
Fred 86 GN
Guest
Picked up my new (reman.) master cylinder and vacuum booster to do the long awaited power master-to-vacuum brake conversion. I also have a line-lock solenoid I plan to put inbetween the front brake line (to the rear reservoir) and the master cylinder. Asked for a 6" length of brake line at the store and found the 1/4" diameter to be too small and the 5/16" diameter would not thread into the master cylinder ports. Are the brake lines and fittings on our TRs metric? If so, what size are they (8mm?) and where can I buy a finished piece of 3"-6" long metric brake line?
These things are never as simple as they should be!
Thanks,
Thanks,
