what size inj for LT-70?
turbo grey
what size inj would u guys consider the minimum to safely fuel a lt-70
turbo??
would 55#ers do the job?anyone using this combo?I recently purchased these inj,and wanted to sell them to get 72's,but have not had any luck. I dont want to give them away,so i'm thinking of running them,and if need be add a 7th inj.
Id go 83lbs minimum or youll be upgrading once you start pushing the limits of the carIMO.
One 60lb 7th would still only give you 65lb injectors.HTH
I'd maximize what you have first since you aren't in a hurry to sell and buy.
Got about a half second to go in ET's which could take a while to achieve.
Assuming you will be running about the same about of boost with the new turbo and all first time at the track.
Also assuming you have a good scantool to monitor pulse widths and duty cycles. :)
Obviously when upgrading later on bigger is better. :D
Keep them up for sale and hit the track. :)
From our own findings , the 75s will go to about 640-650 RWHP.;) ;)
I would say the 55's will work for a while I have just put a pair of 50's in a car with ported heads, stretch intercooler, and a Stealth 70 and on 22psi its not out of fuel yet so I would say you will be ok until to the 28-30psi range.
