What size pushrods.
tatoGN
junior member
Hi, I'm puting the engine back together and i want to fit the TD rockers under the stocks valve covers with the RJC extention. What size pushrods do i need? I'm using roller cam morell lifter with stock irons. Any help.
Thank you!
IMO all motors are different...I would get a pushrod checker from COMP...not that expensive...the tool is calibrated...so you know the length each turn...find zero lash...then add another .030-.040 for preload and that's the size pushrod you need...since you're using T&D's and they are adjustable you don't have to be that exact on the length...the T&D's allow a little play on the adjustment...
X2
Check each push rod individually.
They will all be different lengths.
Then pick a length that's in the middle of the shortest and the longest number.
D
