What spark plugs
May depend somewhat on what you have had done to your engine but alot of guys (myself included) use Autolite 24's for the street. I use the 23's (one range cooler) for the track. HTH
That will work just fine, or use AC R43TS. If you're equipped with a larger turbo, higher boost levels, etc, go with AC R42TS.
...or, the Autolites, whichever's the least expensive.
What plug gap are you guys running with larger turbos.
Still at .35 I heard some people have had a misfire from higher boost, so they closed the gap to .33 True or false
Rick
If you are running in the 12's use the CR42T's, if not slower than that use the 43's.
