what stall? gt6776s
In youre sig it states youre running a ptc 3200 stall.which sould work fine.you might want to lossen up youre stall to 3600 call dusty he is a ptc dist and HE can hook you up.
thanks humble u2. i saw that turbo on ebay and thought what the hell ill bid on it but with you info ill pass i dont wanna go into a bigger stall.. i plan on gettin a gt76 bb turbo in the future
what would be the correct stall for this turbo gt6776s.. thanks in advance
Depends on what your et goals are. At your elevation if Vegas is correct you'll need something in the 3000-3200 range with that turbo but your shift point also plays a roll in the final stall needed.
Nothing will work with both the 67 and the 76 later down the road. 2 entirely different set-ups are required.
