What stall would be good for a T66 with a .85 housing? I'm looking to upgrade from a TE-60 to the T66. I have a 10.5" 3500 stall in the car now. Also can I use the wastegate off the TE-60 on the T66? Thanks, Jason
Originally posted by Jas89TTA What stall would be good for a T66 with a .85 housing? I'm looking to upgrade from a TE-60 to the T66. I have a 10.5" 3500 stall in the car now. Also can I use the wastegate off the TE-60 on the T66? Thanks, Jason
I got the convertor from CK Performance it's the 10.5" lock-up with a 3500 stall. I'm going to upgrade the injectors to 72 lb injectors and get the ECM driver upgrade. Thanks, Jason
4000 is way too much. It's not very streetable and is not needed. I am playing around with convertors now for my GT70 and I can assure you, 4000 is too high for that one as well.
