What stall with T66 Turbo?
Jas89TTA
What stall would be good for a T66 with a .85 housing? I'm looking to upgrade from a TE-60 to the T66. I have a 10.5" 3500 stall in the car now. Also can I use the wastegate off the TE-60 on the T66? Thanks, Jason
3500 will be good, but 3800-4000 would be awesome.
Which converter do you have now?
Just an observation---but if you havent upgraded the injectors listed in your sig------you are in for a BAD day with the turbo you are looking at.
Geoff
I got the convertor from CK Performance it's the 10.5" lock-up with a 3500 stall. I'm going to upgrade the injectors to 72 lb injectors and get the ECM driver upgrade. Thanks, Jason
Re: Re: What stall with T66 Turbo?
3500 should be enough.
4000 is way too much. It's not very streetable and is not needed. I am playing around with convertors now for my GT70 and I can assure you, 4000 is too high for that one as well.
