Technically, due to the small shaft of the turbine wheel, you could have it upgraded to a PT6776H non ball bearing turbo, as the bearing housing I believe is the same as used on the 6776H. Although it could be expensive and here's why:
Parts that could be kept, if they can be reused.
Bearing housing
Dog ear bracket
Parts needed for upgrade.
Bearings, oil seals, retaining rings, 360* thrust bearing, backing plate, compressor cover, compressor cover backing plate clamps, backing plate bolts, 90* hose barb fitting, compressor wheel, compressor to turbine wheel nut, P-trim turbine wheel, heat shroud, turbine housing, turbine housing clamps, turbine housing bolts, oil return gasket, oil feed fitting, new wastegate actuator with correct clamps to mate up to the compressor cover you choose. Basically everything would be changed, so it could be expensive.
It would be much cheaper to upgrade it to a PT6152E as technically only the compressor side components would be changed if the CHRA and turbine wheel are in good shape.
HTH
Patrick
