SignUp Now!It depends… If your car is a "matching numbers" car and you want to keep that way, then have 6 sleeves installed in the block (to the standard size) and have it rebuilt with standard size pistons and it'll be good as new.My original block is good, but .40 over. It had some serious metal flakes go through it, so just wondering what you would do with it
Your car will always be more valuable if you have the original block even if it's damaged, but can be repaired.
I was leaning towards sleeving it. Any issues getting standard size pistons, or is it just cheaper to find redily available 10 or 20 over?
Sent from my SM-N900P using Tapatalk
I bought another used shortblock, because a local Buick guy told me it was a bad idea to use my block since it was already .40 over..040 is not a problem. We have run them as much as .060 over. What exactly is your concern?
