What to do
Well first of all decide what you want to change. First thing personally I would do since the motor is out of a car is to freshin it up. If budget permits even take the engine complete apart. Send it off to a machine shop" A GOOD MACHINE SHOP" get it honed,machine the rods, and crank. Magnaflux everything you can. Maybe even o-ring your block for copper gaskets,blue print the engine,zero deck it,balance it. Put arp studs all the way through and torque every bolt down to specs and losen them and retighten the bolts to spec. If budget allows some port job,valve job to the heads if so get some gn1 heads. And a v-3 intake by tm and whatever turbo that will fit your combo. Remember your gonna need a bigger fuel pump,adjustable fuel pressure reg, bigger injectors, new chip"jay carter",headers"poston,atr"down pipe,up pipe, crossover, And with lots of tunning you got yourself a pretty damn good hot air. And with lots of tunning you might even see the mid 11's or faster with a good combo and I cant stress this enough you can put the greatest parts in the world on your car but with out extensive tunning your not gonna get your car running good. I learned this the hard way.
Allan
