This is whats going on
200r4 behind a 500Hp/125 shoot of NOS BB455 Buick in a 79 Regal with 3:73gears.
The 200r4 was rebuilt with GM parts BUT with a standard valve body.It shifted good but under torque was sloppy going into 2nd.After following the do's and don't from the people in the know on this board now for the last year I can see why it's like this.
So I picked up a GN tranny for it's internals.I have swapped out the governor and the servo.
Upon removing the pan on the standard tranny I found a Trans-go shift kit in it.Now there is a plate that says[NOYOGUPPY/Reverse fix/GIL YOUNGER].Since I don't have the instruction manual for the kit and also it looks like they make 2 different kits for each [hi-po-standard]valve bodyI don't know if I should get a set of instructions for this shift kit and just transfer everything from it to the GN valve body or buy another or better kit for the GN valve body.
I would like to just re-use the Trans-go kit if possible so I would need to find a installation book or if I need something else what would be a recommendation?
