Ok..making a safety device..what circuit could be killed and the motor be brought down in RPM's safely without losing total power.
Idea is for NOS,alky,propane whereas if under high boost and ya lose the adder..you can bring the motor down..kinda like a rev limiter.
I'm thinking TPS be brought to 1.5 volts via a relay with a simple voltage divider..that ought to cut the fueling and timing.
How bout the MAF..bring that one down to 2.5 volts..looking for ideas..aside from killing power to the ECM..
interrupt the crank sensor? until boost is at a safe level?
thanks guys..making a better mousetrap
Julio
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
Julio
