fastlikeanascar
Its never fast enough !!
- May 4, 2008
What should I use for alky ?
SignUp Now!Which kit? You could always ask the manufacturer too.![]()
Anything with water mixed in will lean out your tuneup. Meaning if you tune the car on 100% alcohol.. then go to 50/50 your air fuel will rise(lean)
Another in a pinch option is the product HEET available through stores like WalMart..
If you buy 5 gallons.. it will last you many months..
The VP Meth at Maple Grove said it is w/lube. We don't want that on the new Razor and SMC kits right?
Good info above thanks.
Razor hit us back on the lube aspect, I thought it didn't matter on your kits concerning the lube.
Am I the only one running with a 50/50 mix of distilled water and 90% isopropyl ? Been running that way for about 7 years or so without any problems with a DIY kit. Plenty of 24lb boost runs without any knock.
