What type of nozzle to get?
85begalttype
just a v6
in few months im going to purchase the razor alky kit for my hotair. i currently have my intake manifold off to do some porting. i cant afford the alky kit right now but i want to put my manifold back on so i can drive the car. i want to buy and install just the nozzle so i dont have to take the turbo and everything off later. i saw that mcmaster.com sells nozzles. is the correct type i need is the 15gph at 100psi, misting/fogging type part # 3178K77
McMaster-Carr
the 10 or 15. 10 if its going to be stockish.. high teens low 20's for boost. 15 if your going to get more aggressive with it.
You need the nozzle, elbow, sealing washers, adapter and cap so it doesnt leak vacuum. Nozzles are 15 from me with the above parts.
Most install the nozzle in the gooseneck that attaches the turbo to the intake. Not the intake itself.
thanks, i will get the 10 nozzle then since i dont plan on going more than 20psi with my hot air. i will install the nozzle in the turbo adaptor. when i get your kit i wont have to take anything apart, just remove nozzle cap and screw in the line :cool:
