I have been running Castrol Syntec full synthetic on the new motor, I believe it has 5w50 in it now, or maybe 20w50...
Problem is when I start the car it takes a couple of seconds before the oil pressure shoots up..it goes to 75psi and it's fine everywhere else but I just don't like seeing 0 while the engine is starting up. What would the best weight be to eliminate this problem? I've replaced the cover and put in the blue spring, that helped my startup oil psi and my hot idle psi increased a few lbs. Just want to get rid of this startup problem, there's no noise anywhere but I don't want to take any chances.
Also, would it be a terrible idea to switch to Mobil 1 or should I stick with the Syntec?
