turbov6joe
Signal 1 J-12
- May 22, 2002
Last night I took the TTA to the track with the following changes:
Switched from Nitto DR's (245/50/16) to MT's steet ET's (26/11.5/16), and installed a set of subframe connectors. Two weeks ago at the same state of tune, the car was running 118 MPH off of a 4 psi launch and 60's in the 2.0-1.9 range. Last night the best I could get out of it was 113 MPH at the same boost. I've always heard that switching from a hard radial to a slick type tire will cause a lose in MPH, but does this seem normal to you all? Somewhere in the time frame of 2 weeks the car dropped 3 MPH in the 1/8, and 3-5 MPH in the 1/4??? The only positive side of this was that the car turned it's best ever 1/8 and 1/4 mile ET's on much to be desired 1.87 short times. The overall picture of things as far as ET's were concerned looked good, it was just the MPH that was down! Any thoughts???
