What ya think this motor is worth???
fatride
Senior Member
Thinking of selling the 109 motor to build a 4.1 I would sell it as a short block. .30 over TRW Forged pistions, 2 Billet Caps, ARP Main studs, Stock crank, rods (std.) King bearings, Billet .495lift 224 duration roller cam, with roller lifter, 8.85 Hardened push rods, front cover, oil pan, This motor has gone 10.70's I might also sell seperate Fully ported GN1's with reciever grooves. I just went through the motor and put it back together. My plans change everyday with the car and now I want to do the 4.1 What you guys think is a good price for the motor???????????
Here is a pic of the motor.....
Dennis if you want it come get it! Gets 20psi oil press. hot! We can take the car out and spank some rice, then pull it out :)
I'd say give it some time and that thing will be a screamer. Just needs a litle TLC.
Steve :cool:
Steve, after I figure out my fuel pump problem the car should run alot better. Also i THINK i WAS ONLY RUNNING 15 PSI AT THE TRACK. If so the 12.20/12.30 runs aren't to bad for that boost. and running 72psi of fuelpressure. Had both pumps wired together. We'll see what happens when I get the bugs out. Sholud still be mid 10 sec. ride.
