87 GN with T-Tops
Rebuilt motor
Moly rings
Comp 206 cam
Comp valve springs
Fresh 3-angle valve job
Port and bowl work done to the heads
Comp double roller timing chain
Melling high volume oil pump
Melling cam button
TE-34 Turbo (T3/T4 57 trim 545hp capable)
38 lb injectors
ATR 3 inch SS downpipe, with external wastegate and test pipe
Hooker 2.5 inch dual exhaust
Custom 3 inch intake pipe with K+N filter
Adjustable Fuel Pressure Regulator
Walboro 340 pump and rewire kit
Scanmaster 2.1
Alkycontrol.com burned ecu chip (NO ALK in car though)
215/60/15 front tires
275/50/15 rear tires
All tires are like new BFG Radial T/A
Digital dash
Shift kit in the tranny
Power windows
Power locks
Needs grill filler installed, a new rear driverside floorboard (t-top leak rot), has a rust hole under the passide t-top near the front a-pillar about a quarter in size (aswell as surface rust all around it) as well as one on the roof above the rear driverside window about a 1/8" wide and 1/4" long also pretty much the interior gutted and replaced.
Worth dealing with the cancer in the body? He is asking 5,500 btw. Have more pictures but you can pretty much get the idea from the ones I have.
Thanks in advance.
Rebuilt motor
Moly rings
Comp 206 cam
Comp valve springs
Melling cam button
38 lb injectors
Scanmaster 2.1
Digital dash
Power windows
Power locks
Thanks in advance.
