Hey guys,
I'm not sure if this is in the right section but I'm looking to get back into a GN and have been checking out a few cars over the past few months. I found an 87 GN hardtop, fully loaded, with around 150k miles... all original except for a catback exhaust. It is a fully documented 2 owner car with no major rust, just some surface rust on the inner bottom door seams and a very small bubble on the lower rear 1/4 panel. It still has the factory paint, which is in bad shape. It's a 20 footer and could use a respray in the near future. It does have all new fillers in place though. The interior is mint except for a crack on the dash by the speaker, and it also needs a headliner. The power antenna doesn't work but everything else has been maintained/replaced and is up to date, such as the brakes, tires, hoses, etc.
What's do you guys think it's worth? Be realistic because I would like to base my offer on your input! A decent repaint is pretty costly and the mileage is up there.
Thanks in advance
Thanks in advance
