The TCC assembly is on the passenger side of the pump. It's real easy to change out. After you pull the pan and the filter, unplug the TCC harness to the case and from the 3rd and 4th gear pressure switches. There are 2 bolts that hold the TCC solenoid to the case, remove those and pull it down. Up inside the hole where the TCC went you will see a small snap ring. Take it loose and the little washer sized disc with the hole in it. Once that's out the springs should drop down, if they don't just take a magnet and retrieve them. Follow your directions when replacing the non lock valve and you're set. Also, and I can't stress this enough, MAKE SURE YOU REMOVE THE O RING OFF THE INPUT SHAFT AND THE CHECK BALL IN THE END OF THE INPUT SHAFT. If you don't do these 2 things you WILL burn your transmission up in no time.
