Whats needed to make a vega manual....
frank700
steering box work. I have an s10 box on now that is old and has play in it and I'm looking to get rid of it. Heard some use a vega manual box. What is the best manual setup? Thanks
are you talking about a new box in a vega? or swapping out the power steering in your TR for manual?
A.j.
Already have an s10 box in my Gn. It's old and needs to be replaced. Looking for any other ideas on a manual box other then the s10 box. Thanks
that I know of, there are 2 options besides the S10 box
TRZ rack and pinion setup
or
flaming river's 16:1 box.
both are supposed to be very good.
A.j.
I'm running a 16:1 Flaming River 16:1 box, what do you need to know?
Check the pics in my sig, everything is there.
Billy T.
gnxtc2@aol.com
Have you adjusted the lash in it at all? It's not hard and this may be your problem.
Really? Don't know could you please explain this lash. Thanks
If you lookd at the top of the gear box you'll see a diamond shaped cover with a bolt and nut arangement on the top of it. Loosen the nut and tighten the shaft until the slack is taken out of the gear box. If you get it too tight it will bind and back it off 1/8 turn at a time.
