Whats the best way to plug a internal wastegate?
tommynos
worldwide flooring sales
I was going to use a internal wastegate and now have decided to go external and need to know whats the best way to cap the hole?
By the way the downpipe has the internal built into it so does it even need capped off?
Can I just put a freeze plug and beat it in,or does it have to be welded or what do you know works the best?
Thanks in advance..
Go to www.rjcracing.com they have a plate that you bolt between the turbo and downpipe.that's what I run on mine
Incase anyone ever wants to search this,I used a steel freeze plug size 15/16 that fit in the puc hole with some force and then tack welded it for extra security..
