what's the opinion on the TPS TEC enhancer?
Tom Tom Turbo
Turbo Goes Woo Woo
I guess I never really noticed them before, but do they really work and are they worth $85? If you have used one, let us know if you picked any noticeable gains up.
Thanks!
if the TPS isnt set properly then it really wakes the car up
TPS ENHANCER
I had one on my GN and it worked great. it insures a 4.8 volt signal at WOT no matter what the tps is set at. but it does cause mixed reaction with some people though. basically it just sends a phoney volt signal to the ECM to allow max fuel to be run through the injectors. if your car is proplerly tuned though and all sensor are adjusted correctly theres no need to spend the money on this part as it will not give you a greatly noticable gains.
Don't waste your money....
Set the tps sensor up properly and you'll be fine. If you want a $85 doo-dad then go for it.
I can't recommend it.
John
I bought one because I was not seeing 4.8 on the scanmaster.
Put it on and the car went lazy.
Took it off that same day, started sticking my foot through the floor board, got the 4.8 and the car was hauling.
Only worth it if your having tps problems.
Had one. All it did was short out and give me wot fuel at an idle and washed my oil with gas. Needless to say I took it off and have no desire to buy another one. Didn't notice a difference once it was off anyway.
