short_dustin
- Mar 14, 2005
I recently bought this car and I saw this connector on the ignition control module plug and I'm not sure what it goes to any ideas?
SpooledUp said:Should be the same wire......People usually hook it up at the green plug behind the alternator but it looks as if they took the signal from the module instead. Only hook it up at one of those areas not both.
So does the signal wire go to the green connector by the alternator or to the wire the blue connector is on?
yes , the 5th pin in off firewall at module (white wire- pin E) is the same tach signal as the connector behind alternator
but thats a 3m scotchlok connector and its not a weatherproof connection and the tap is steel and not corrosion resistant , sooner or later it will cause issues in the wire its tapped into
