turbov6joe
Signal 1 J-12
- May 22, 2002
Postal,
Just a couple of things in reference to your original post.
#6: I would refrain from wrapping your headers and have them jet hot coated instead. Both my pop and I have had headers that were wrapped and both of us had our headers litterly fall apart due to what I believe was over heating them and moisture. The wrap works SO WELL that the headers get SO HOT that the metal gets fatigued and breaks down due to repeated heat cycling...trust me here! You could almost punch holes through them with a screw driver. My opinion is that the gauge of the metal is too thin and the heat kills em. TTA headers are way too hard to find to risk it IMO. The is no denying that the wrap increases exhaust velocity and decreases under hood temps, but the cons out weigh the pros here. If you run your EGT's anywhere near what I do (1650º+) you can damn near melt metal with heat like that. Last thing you want to do is make them any more hot.
#5: I like the way you think and it sounds like a good idea, but wouldn't have GM and all the fast cars over the last 17 years done this if it worked? If you do it and it works please let me know, I'm open to any suggestions to make my car faster!
#2: The 400 tranny weighs a lot more than the 200 and takes quite a bit more HP to turn, thus a loose/loose situation on both ends. If you want BIG stall, an option would be to go to a #6 pump Precision Industries 9" converter (~3800 rpm stall depending on what kind of power your motor makes) with a 5 disc lock up that will handle about any power you will make anytime soon. This way you have the overdrive of the 200, the reduced weight, the reduced parasitic drag, BIG stall to launch with and a 1:1 ratio when locked and the car stays stock as far as the driveline is concerned. The 200 can be built damn near bullet proof these days, no need to worry about that.
#1: Tranny Brake...pushing problem solved and killer 60' times to boot! I had WELL over 100 tranny brake passes on my STOCK tranny before the clutches took a poop...and that was a 15k mile tranny with nothing more than a shift kit.
