turbo39151
anycoloraslongasitsblack
- Nov 7, 2002
Ok here's the scenario:
I want to run stock rims with stock lugs for car shows. (I have these on the car now)
However, I also want to run my WELD Prostars...
Probelm is twofold:
1. Welds have a 1" (or deeper) center which basically swallows the whole stud...
2. The holes for the studs on my fronts are actually a narrower diameter than the rears! (Note: All the rims are WELD. All are 15 x 8. Fronts are 4.5" bs and the rears are 3.5" bs)
Questions:
What is the length of the shank (lug) that I will need for my weld rims? (so that I can keep the stock length.) I called Summit but thery were useless...
Will I need closed end or open end lug?
I am under the impression that, for track purposes, I would need to have some thread protruding from an open end lug. (ie: longer studs) Is this correct?
Please advise. The lugs I have barely fit so I need to send them back and re-order...
TIA
Probelm is twofold:
Questions:
TIA
