A
AsphaltAnihil8r
Guest
Ok.had 2 bad studs so I smacked them out with a hammer,,pretty simple...I can get the new studs back by turning the axel in small amount to a certain spot that provides me enough clearance....
But I guess you cant use a nut to draw the stud in (stripped the stud),,,so it appears I need to remove the axle to press the studs in from the rear---so HOW do I remove the axle....
thanks Dennis
thanks Dennis
