When to upgrade from the stock throttle body
"Turbo-T"
V6 on steroids
Just wondering, when would a throttle body swap from stock be considered ideal?
Thanks.
upgrade
I traded my bluetops for some #60's really helped my combo.you have to be getting close on duty cycle with those 36's and the 60 size turbo
have you had it ported yet?
I would consider that to be the first step.
I had mine rebuilt and ported.
Better throttle response at the least.
Jim
I've asked about this...been told the 36's are fine for now...per a few people, one of them being Dan (Grumpy)
Jim
Is it even worth porting the stocker? That means a new throttle blade too right?
it all depends...some will say yes others will say dont bother....i had mine done, and for what I paid, I think it was worth it....i believe my throttle shaft seals were part of a vacuum leak issue I was chasing.....seemed to idle much better after I had it done, plus it was all cleaned up...was able to remove one problem from the equation by having this done
(Is it even worth porting the stocker? That means a new throttle blade too right?)
It also solved a vaccum leak at the TB for me, and the porting blended the TB with the upper plenum perfectly.
I thought it was money well spent.
Jim
I would not touch the TB = try to tune your combo the best you can.Just my three cents ..:D
I agree. I'm running high 10's@124+ with a stock throttle body and a mild build. Spend your money on something else. JMHO
Thanks. Not sure what my next mod should be. I've got the big stuff...TT chip, alky, 3 inch downpipe, 3 inch exhaust, injectors, turbo, intercooler is a stocker but has the Dutt neck. All of my mods are in the sig.
i have a very similar combo to u, save for the alky....i didnt do my tb to add hp, I did it to clean things up and eliminate issues down the road...mine had a ton of miles when I picked it up, and i was chasing some idling issues...i did the tb and plenum to eliminate them as possible problems
