Feb 17, 2002 #2 E ES1 Active Member Joined May 23, 2001 Messages 1,244 Read this area of the BB. Alky cools allowing more boost without detonation. Like Steve Y said in a post, it has been used in planes a long time.
Feb 17, 2002 #3 O OKTurbo Member Joined May 28, 2001 Messages 611 Probably the best compilation of info can be found here.... http://www.geocities.com/rad87gn/tech/alcohol.html Chad's page helped me when I was looking into it/ I went with the SMC kit on my 87 GN. There a LOTS of guys that use alcy injection on this board. Frequent the Alcy section and you will learn everything you need to know. Good Luck, John
