Originally posted by orion
so how'd you do it? NICE car by the way, looks really clean and dark as hell. but is that a brown interior? Are those the lear seats?
HA - No, the interior is Graphite grey. Front seats are out of a 2000 TransAm, the rest of the interior was done to match it. Center console is out of a Monte SS (arm rest!).
I did a complete custom job on the doors/panels to get them in. Others have said they've put 6.5s in behind the factory CSII panels (i still don't see how)
My way is a little complicated.
-Move the power window motors rearward 1/2" for a little extra space (this is really easy)
-trim the lower door panel for the speaker (it'll fit up inside the angled part...give enough clearance for a grill)
-put the panel on the door and trace the hole on the metal
-trim the door metal to match the panel
-Make a 3/8" spacer ring (2)
-mount the ring and speaker to the door metal (not panel)
-fit the panel on and trim out the door panel (More) so it doesn't interfere with the speaker (speaker will come through the panel)
- mount the grill & assemble it all
I also went a little further with mine and made a one piece bottom (front to back) and relocated my window switch just to make it look a little cleaner.
Maybe some of the other guys will chime in with their simpler way to do it but with the speakers I used (Diamond Audio Hex 600s) This is what I had to do to make it all fit and not hit anything. Make sure to check all your clearances (window & wiring) before buttoning it all up.
