Where to buy 3" hose between turbo and MAF.
you want a used OEM one ... I have its in fair condition...
'No' on the OEM, but thank you.
I am replacing a 4'-5' length from my Pete Tomka set up due to wear and tear (after 14 years). I don't have a MAF and my air filter is down behind the bumper, hence the longer hose. I am considering the hose that is in your second link below.
Thank you.
a couple clarifications on the above links...
the Pegasus ducting is really vent ducting for brake cooling or cockpit venting. you want a 2-ply duct whereas the wire reinforcement is sandwiched between the layers. even though Pegasus makes a 2-ply duct, it is lacking compared to the product specs of aircraft ducting.
the aircraft industry has what you want - the CEET rated or equivalvent 2-ply ducting. CEET has better temp/pressure/vacuum operating range than the Pegasus venting duct. I had explored this at one time.
from aircraft spruce, the CEET equivalent is the VENA MTD product. not the VENA MT (single ply) link above from grassdoc - correct company, wrong bookmark. link below.
additionally, aeroduct brand CEET ducting is available from wicks aircraft. link below.
Original FlexFab MAF hose is 16" long ( 15 - 15/16 in, as I measured a NOS one - never flexed)
ORDER 4 FEET AND YOU WILL HAVE THREE STOCK LENGTH HOSES
3" (CEET-12 size) VENA MTD (CEET equivalent) from aircraftspruce is $8.75 per foot. 4" ( CEET-16 size) is $11.50 per foot.
Aeroduct is slightly more expensive than the VENA MTD...
3" (CEET-12 size) AERODUCT from wicksaircraft is $12.24 per foot. 4" ( CEET-16 size) AERODUCT is $13.76 per foot.
images of hose, spec sheets, etc. are found thru the links below. AERODUCT has the wording "AERODUCT" printed on the outside of the hose in a diagonal repeating pattern. see image on product page. the VENA MTD hose has no wording on the outside - just a black hose with white/gray spiral reinforcement on each side of the spiral wire reinforcement about the circumference. see product image.
https://www.aircraftspruce.com/catalog/appages/ceet.php
http://aircraftproducts.wicksaircraft.com/viewitems/aeroduct-hose/aeroduct-ducting
informational overview video I'll post as well:
http://www.eaavideo.org/detail/videos/feature/video/46874087001/ducting:-scat-sceet-cat-ceet
REFERENCE: posts 17, 18, 20; https://turbobuick.com/threads/stock-intake-tube.460659/
Pete Tomka used Aeroduct brand product. any length you need from either aircraft supply company I noted. remember CEET equivalent...
didn't post the CEET Anthony bc its that ugly ass orange LOL.. as always thank you for your info ive learned a lot from you my friend
Pegasus has 2-ply in both red and black but the CEET is the better material. CEET is black. SCEET is Red.
Anthony P: Thank you for the great information. I had already ordered the Vena MT from Aircraft Spruce, before I checked back to this thread, so now I will have to call them Monday to change the order to Vena MTD. Thanks again.
Your are correct about the 'ugly ass orange.' I did not want that. :)
sorry it was a quick post ...Anthony P set it right ... the S-ceet is the orange .. just a quick response from me ...
