SignUp Now!Autozone sells the Cardone reman. units which have lifetime warranty. The price has gone up a bit recently due to low core availability, but still way less than prices above. I think they've gone up to around $300 from a low of around $100, but you should still be able to get one halfway reasonable. Only problem is that too often it is required to take advantage of that lifetime warranty..Check the price of the TR unit against that of the Buick Roadmaster/Station Wagon unit. I think the latter is cheaper, and is the same... although you might have to use your old reservoir??? Someone else here will be able to confirm. It's been awhile... I converted to vacuum long ago and won't ever have to sweat that POS again!!!
Edit - also.... check autozone online prices (you have to enter your ZIP), and then CALL the autozone near you. They seem to have sometimes LARGE price discrepancies between the two based on your local.... check both applications both places....
I got a GN part list from Cars, Inc. with my last order, and they show a Genuine Delco Complete Powermaster setup for $1,750 part#18030823 and they also have a Gen. Delco Reman. for $1,150 part#18030823R.
GL
Mark
hold on... I'll find it and send you a link...... oh... and about $150 to convert to vac.... that was with NEW napa parts......
You should first find out what's wrong with yours, it might just be a switch or an accumulator. Don't give up so easy and look to replace the whole thing. You can also get a brand new pump for it for less than $200.00. Do some searches and you will find the parts.
Kirban Performance Products, one of the board sponsor vendors sells a reman by Cardone for around $450 + exchange with a lifetime warranty- check there site. HTH's![]()
The brakes are working fine I just get this sound like an external fuel pump coming from the dash and it is leaking.
Man only $150 compared to $1750 for a whole new unit.![]()
