I'm needing to find a check valve for the PCV valve. I want to make certain that I'm not pressurizing the inside of the engine.
Thanks,
Steve
All of the aftermarket valves dont function right as they wont open at vacuum. The GM one probably does.. the one I posted does if you modify it.
How do you modify the one you posted to make it work?
I went to Orielys and got a Vacum check vale for a GM vacum brake.
Jogging the memory, that is what the GM part # I listed is for I believe. For what it's worth, there is a similar 90 degree barbed check valve unit for the Mustang as well. Don't remember if they both were black in color if that makes a difference to you.
maybe worth a trip to your local autoparts store just to do a looksee then make a decision.
go to home depot, plumbing, brass stuff, get a couple of barbed fittings and a union, go home an rip apart an old caster laying under your work bench for the ball bearing, take apart a ball point pen for the spring....cobble it together and walla
go here Performance Systems Manufacturing, LLC You will find it under products, under the name of SUPPLEMENTAL POSITIVE
CRANKCASE VENTILATION VALVE, it works great.
