where to get wastegate solenoid
cetme1
Ok I found another problem while doing spring cleaning.
My wastegate hoses and solenoid filter were FULL of oil. I need to replace them. Kirbans has the hoses. But it appears that the wastegate solenoids are now on the endangered list. I think they use to be relatively inexpensive.
Anyone know where I can get a new one? I found one but its about 200 bucks:eek:
Question on this. The stock chip controlled wastegate solenoid will allow for different boost in different gears right? (I'm using an old Thrasher chip)
Will this manual boost controller do that or are you stuck with 1 boost setting thru out all the gears, until you manually change it?
One boost level all gear but that's assuming everything is work correctly.
