where to mount overflow.
paccio
Hey Razor,
Where is the best place to mount the coolant overflow tank. In
your directions you say between the battery and the alky tank?
Do you have any pics?
Thanks Phil
on OE fan you can just mount it upright along side of the fan securing the two hangers into the side flange of the fan housing , I had it this way before going dual fans
with dual fans I mounted it laying flat with the hanger screws underneath and the hangers pulled to the sides secured into the fan housing just above the passengerside fan , only problem i had wasa little coolant blow out throught the vent holes in the bottle neck , i plugged those and run it with minimal fluid.
edit ,
just realized you were installing on a TTA which explains why the tank wouldnt fit there on my GN when i was told told to put it there , in your case ignore the above, but for regals it works
Another place is on the drivers side. Will need a longer hose tho.
under the battery
I used an overflow bottle from a Chevy truck & bolted it under the battery, out of the engine compartment. :)
