Pics
Well, I wish I woulda taken some pics before I put it all together. I can tell you what I did, for future reference. I have concert sound, so I replaced the front door speakers and front dash speakers with a set of 5.25component Blaupunkt speakers. When I took the existing tweeter out, I ripped out the speaker and used the surrounding plastic from the original speaker to mount the new tweeter in. I had to drill out the center with a 1" drill saw? Not sure what they call it, but it was in my Ryobi drill set and worked perfect. I also reused the existing pods from the door speakers for my new speakers, this also worked awesome. One of the corners was riveted in, out of the 3, I just broke this corner away from the original speaker. I bought a set of 6X9 Polks from Crutchfield b/c they came with the adapters. I HATE these adapters, but did get em in and working with some love from my pliers. I added a 500 Watt Sony Explode AMP from UBid and an 8" DUB edition self powered sub from Ebay.
The worst part of this job was routing the speaker wire from the dash tweeter into the door. These particular speakers have the crossover built in, and the tweeter needed to be run to the 5.25 speaker. Seeing as I didn't want to change the door panel, AT ALL, I ran the wire down from the tweeter, thru the door boot, into the door. To run 2 of these wires, it took me nearly 3 hours of messing around. I used a wire coat hanger, lots of Busch Lights and some patience.
The other problem I had, until I came here was running the amp power wire. Frame rail is the way to go. I will try and get some pics up of everything that can be seen.
All in all, I put about $300 into the system. My car came with a nice new Kenwood deck, so I had all the pre-amps I needed! Car sounds real good. It's not competition, but for the money I wanted to spend, I think it sounds great!
Hope this helps someone in the future...
Ryan
