V8, On gnttype there is a pic of sensor locations under resources. The Iac valve is under the uppipe going to the throttle body it is brass colored with a four plug black connector. The screw to adjust the IAC is on the driversside next to the vacuum block on top of the throttle body, it may have a gold cap on it.  The TPS sensor is on the passenger side of throttle body and has two screws holding it on it has a black connector on the front of it it is right next to the uppipe.HTH
