josh young
- May 12, 2008
I've decided to go with one of the two either kirbans or accufab. I've read good and bad on both. Who runs what? I've always thought accufab was top line? Am I wrong? Thanks guys.
SignUp Now!I've decided to go with one of the two either kirbans or accufab. I've read good and bad on both. Who runs what? I've always thought accufab was top line? Am I wrong? Thanks guys.
Yeah Earl i still have that accufub NIB... knock 50 cents off the mic's you can have it...One day I saw powerlogger logs of a Kirbin .vs an Accufab on the same car. The Kirbins performed nice and smooth and the Accufab was choppy and all over the place and incosistant as hell. After send it back twice, I believe, with no changed, the Kirbins was put back on and went back to working as normal.
The Accufab wouldn't hold pressure after key off and the Kirbins would for what that's worth.
After seeing the logs with my own two eyes, I took the Accufab apart with my own two hands..... The first thing out of my mouth was "I don't see any way this could fucking work the way it's supposed to". Then after a little while I said ''Perhaps after a long time, the steel ball would pound it's way into the 45* aluminium bevel and make a sealing surface that would seal... but that's only if the ball was perfectaly spherical... which it's not."
Needless to say If I ever buy another FPR, it won't be an Accufab.
You know, for what it's worth
That was Jerryl and me. It's in Jerryl's post. You can search fuel regulators by Jerryl. I posted the fuel logs of 3 regulators. The best regulator actually was a Bosch 237 for being accurate and smooth. The Accuflub is full of issues that Jerryl has carefully explained with pictures. Maybe at one time they were better made, not now. I'm running a Kirbans...
Only problem with that is they will look at it...as funny as it sounds... if i did business like that i wouldn't have any.... I think they need to man up.
