Which air dam when running RJC FMIC?
Blazer406
Mechanical Engineer
I was thinking a full under bumper stock hot air air dam would probably look better......
What are the RJC FMIC users running?
I run a hot air air dam w/front mount. looks good not as tall as aftermarket but fuctional. and picked one up cheap 40.00 bucks. and you can make them taller and stronger w/fiberglass work if you like.
Mark, is there a chance that someday, you'll come up with a narrower one-piece air dam?...The one you sell right now is definitely too wide...:frown: An exact reproduction of the '84-'85 unit would be perfect!...(and maybe sell better too)
Thanks,
Claude. ;)
Actually they sell pretty well.:) By narrower I am assuming you actually mean the amount it drops down height wise?? Will see if something can be done about that.
