Which chip should I get?
Brad_H
Which chip is recommended or which would you get. I want to run 60lb. Injectors and alcohol injection and I have aem inline wb
TurboTweak Wideband Chip v6.1
Or
EXTENDER EXTREME CHIP FOR BUICK
Which would you recommend? Here's what I have
Power logger, 2.2scanmaster, v5.7 chip, 86/87 ecm and smc alky, 3.5 ls1 maf+translator, 3" cold air intake, UEGO Inline controller, Taurus Efan, ported heads to match speed daddy headers, 3" downpipe, Casper knock gauge, stock adjustable FPR, Walbro 340 pump+Hotwire, stainless steel fuel lines
Since you already have the translator, then your best bet would be the extender extreme.
Or, you could ditch the maf and go with the SD2 (speed density).
Posted to TurboBuick.com from my RAZR MAXX HD
What about the wideband chip?
It would also work just fine, although not taking full advantage of the Translator's capabilities. But you can make changes within the wideband chip to compensate.
