I splurged, and bought up about 20 qts of 91% isopropyl. But everybody here says Methanol is the way to go..I have an Aquamist system, and as such, I firmly believe in a water predominant mixture for my supercharged application on my bmw M3. The aquamist pump and nozzles are among the very best, but the pump is NOT meant for an all alky mix...Therefore, I use anywhere between 25% alky up to about 45% alky.
Do you guys think there is a benefit to my switching from my Isopropyl/water mix to a Methanol/water blend? If so, how do you all feel about using the blue Windsheild washer mix? I believe the mix is in keeping with the content Im interested in using, so I could use it right out of the bottle, and I dont see why this wouldnt be a decent way to get into Methanol use. Thanks.
Paul
Paul
