onefastjackass
- Oct 6, 2002
Ok I have an 87GN with the 2004r and don't ike the way my trans lines are running.It looks like someone put different lines in it and they are touching the exhaust tube were it comes down from the turbo.It is running between the block and that pipe.What is the best way to run the trans lines to keep them away from heat.Also should I worry about how long the trans lines are so that I don't have pressure drop or not??
Thanks Kevin
Thanks Kevin
