Hey All, My 87 GN clone lost something in the trans the other day, so off to the trans shop it goes. The guy says he has built several 200r4's, and a few of them for GN's but a lot more for hotrod transplants and stuff. Anyways, I have compression in the 150-160 lb range, but I've noticed if I don't start the car for a week that I have a lifter that talks for a few minutes before it quiets down. The engine was built a while back, so all I KNOW for sure is that it has 42 lb injectors and a TA49 turbo. My question is with those 2 knowns, what cam and what stall converter would complement the turbo? The reason I'm contemplating cam change is my oil pressure cold is 60, but hot is 10 (or less) at idle. If I'm going to play with oil pump/and lifters, may as well do cam and timing chain while I'm there. I will be installing the alky kit too. Cheers!
