I'm going to be installing a trans cooler in my TR this week. Looking at the two cooler lines from the trans to the radiator, I was wondering which ones should be unhooked and routed over to the trans cooler?
In other words, would it be best to run both trans cooler lines to the new trans cooler and totally omit the built in one in the factory radiator?
Or should I run the outgoing trans cooler line to the radiator, then thru the trans cooler and then back thru he trans?
Also no the trans lines, which is the outgoing and which is the ingoing?
Thanks in advance.
Thanks in advance.
