which "Y" pipe with your 3 inch DP.
I am looking for a "Y" pipe.
And the only one I can find is the hooker the problem I have with the hooker is that it is 2.5 in and 2.5 out.
And if I have a 3" DP why would I want a 2.5 line in "Y" pipe.
A 2.5" Y pipe will flow more than one 3" DP, is that what you are wondering??
I have the ATR Stainless 2.5" and would recommend finding a SS Y. They are not around anymore but someone has to have a Stainless 2.5" Y.
I like the set-up from this company because the Y-pipe is really two pipes all the way through. Some y-pipes don't split off until halfway down the system and seem more restrictive.
GN exhaust
I have Cotton's 2 1/2" stainless with Magnaflows and love it.I think you can get a 3" dual system in stainless also from him.
I don't think he has a 3" dual system in stainless. I just bought his aluminized 3" system with Magnaflows a couple of months ago, but I had wanted stainless.
If it's just the Y-pipe you're looking for you can try Torque Tech. You'll have to call them because their website is a mess, but they do sell just the Y-pipe and they do have it in 3". It looks just like the pic above - splits at the flange.
Jim
I found the MagnaFlow in summit but they have it listed as a collector (2 into 1) not a splitter (1 into 2) so I am not shore if the design would be efficient if used backwards (1 into 2) but I guess if I use a 3" and 3" out then reduce it to 2.5 there shouldn’t be much restriction just a whole lot of welding.
In the meantime I’ll look at some of these other kits that you guys posted up they look real good.
Thanks for your replies.
Jim
Do you have a link or # for them.
thanks
thanks Dude
i'll call them later on
You're welcome. You can try Cotton's, too. Last I talked to him his systems were manufactured locally, pretty much 'on demand' so it's not like he'd have to split up a kit to just get you a y-pipe. He can probably have one made.
Jim
Jim
thanks again Dude
