8 87Turbo-TWE4 Member Joined May 9, 2008 May 25, 2011 #1 Blows white smoke that smells like gas when in park for over 5 min. Blows out after a few seconds. Rough idle, strong smell of gas. Any ideas?
8 87Turbo-TWE4 Member Joined May 9, 2008 May 25, 2011 #2 Anybody tell me where to start? I don't have a scanmaster.
S SS502 Out with the good, In with the Bad! Joined Feb 2, 2011 May 25, 2011 #3 Hey 87... did you get a good MAF? I know mine didn't work out for ya, but that's where I'd start.
8 87Turbo-TWE4 Member Joined May 9, 2008 May 25, 2011 #4 i haven't put it on yet but it was acting crazy today. I'll change it out and get rid of that bosch o2 sensor.
S SS502 Out with the good, In with the Bad! Joined Feb 2, 2011 May 25, 2011 #5 Sounds like a plan.. know $$ is tight, but try and save for a scanmaster, helps you and helps peeps here.
J jmccurdy New Member Joined Apr 22, 2008 May 26, 2011 #8 Pull the dipstick and make sure it's not milky looking....if so your headgasket is leaking.Could be a leaky injector also
C challengermike Member Joined Nov 14, 2005 May 26, 2011 #9 White is coolant or just moisture in the exhaust.
8 87Turbo-TWE4 Member Joined May 9, 2008 May 26, 2011 #10 it's going to the shop tomorrow. I beleive it's a hg but I really don't understand how. Idles bad like it's missing
B blackgn1 Set on TSM Boost Joined Jan 2, 2007 May 26, 2011 #11 Your bearings probaly have taken a dump too if it's a head gasket.:frown:
8 87Turbo-TWE4 Member Joined May 9, 2008 May 28, 2011 #12 turned out to be bad valve stem seals causing blue/white smoke. Being replaced next week.
